Mommeeu
#1 Posted : Monday, July 29, 2013 10:04:02 AM(UTC)
Mommeeu
This range is the black version 790.96599601, with the bridge unit on the left, a warming burner at the center back, and two burners on the right.
In September 2012 I was convection baking at 400 degrees. When I attempted to change the temp to convection bake at 350 degrees, I immediately heard a crackling noise and saw a whisp of smoke rise from the back of the unit directly above the clock. I pressed "stop" and then heard a loud pop and smelled burning wires or some other kind of electrical odor. The unit worked normally until just a few days ago. I wanted to provide this background information in case the two events are related.
Recently, I was baking some Italian sausages at 350 degrees on a wire rack over a baking pan in the top third of the oven. I checked them and they were still whitish and baking slowly, so I went into the next room to work on the computer. Moments later, I heard sizzling and returned to the kitchen where I saw smoke coming out of the vent over the range top and an F10-ERR code. I opened the oven door to see blackend sausages and the top coil red hot. I pressed "stop" and removed the pan.
I rotated the sausages and put the pan back into the oven to try again at 350 degrees. Again, they blackened quickly, the F10-ERR code reappeared, and the upper coil was red hot. I pressed stop and also turned off the circuit breaker to the range as I do not wish it to burn my house down. I haven't used it since.
Do you have any ideas as to what might be the problem and what parts might be needed to fix it? We have the parts lists and exploded diagrams for this unit. My aircraft mechanic/auto mechanic/handyman husband has repaired my washer, dryer and dishwasher many times. He leaves refrigerators to the pros and may have to do the same for this, depending on your answer.
Thanks!!
#2 Posted : Tuesday, July 30, 2013 4:14:39 AM(UTC)
Parts for Kenmore Range 79096599601 - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...ingfield/316441478en.pdf
If you go to the Sears parts site they should have actual part breakdown diagrams. Unfortunately they do not share these with other vendors.
F-10 is an overheat error.
Since the unit knew it was too hot the sensor is probably OK and it is the oven control board that is bad.
I would check the sensor just in case, see the tech sheet chart.
Part number: AP3965663
Click on the picture for more info.
Mommeeu
#3 Posted : Wednesday, July 31, 2013 8:09:03 AM(UTC)
Mommeeu
We have the exploded views and parts lists for the range. My husband will check the sensor first, as you recommend.
Thanks!
Guest (5)
