Hi, I have a Frigidaire gler331cas2. Yesterday, I went to use it and when I went to turn the timer knob to the usual 50min cycle, it just slipped! I turned it a few times and no success, it just kept turning without catching on the timer minutes. If I push the knob in harder, it will catch at 40mins, and I ran it once and it worked ok. I did the same again for the next load but it didn't heat so I stopped it. Now, the timer knob just keeps turning without 'catching' on the minutes and/or cycles (like perma press...) so I'm thinking I need a new timer-dryer part. Is the part I need AP2107515? Is the gler331cas2 model the same as the gler331as2 model? Any suggestions or recommendations would be greatly appreciated. Thank you very much!
Yes, the timers should be the same. |
THIS FORUM IS DEAD!!!!!!! |
