The water dispenser inside my Kenmore Coldspot 106.74254400 doesn't work. I accidently hit it & it stopped dispensing. This happened a few years ago but it started working again when I accidently hit it again. (Yes, I've tried hitting it but no luck). The water filter is new. I saw a post said it could possibly be the water line inlet valve OEM. Could it be something with the spring dispenser? I'm hoping for an easy, inexpensive fix.
Thanks,
Marylg
