lvBake
#1 Posted : Saturday, July 27, 2013 6:51:42 PM(UTC)
lvBake
GE gas range oven displays flashed "Locked Door". Can't bake! When it first happened, if I pushed the door hard when it was closed, sometime the flashed "Locked Door" disappeared and I was able to bake. Now, no matter how hard I push the door, it is still blinking and I couldn't bake at all.
I replaced the motor, did not fix it. I replaced the control panel, did not fix it either. I am very frustrated. Please help!
lvBake
#2 Posted : Saturday, July 27, 2013 7:00:23 PM(UTC)
lvBake
Is there a way to reset the system?
Is there a way to disable the useless, error-prone self clean/lock door feature?
