Napi333
#1 Posted : Friday, July 26, 2013 4:07:12 PM(UTC)
Napi333
Water and ice not dispensing although ice is being made. It worked when the light switch in the freezer was jiggled. Replaced switch, but still no dispensing unless the switch is jiggled. What can be the problem now.
HumboldtRepairMan
#2 Posted : Friday, July 26, 2013 4:48:15 PM(UTC)
HumboldtRepairMan
Sounds like you have a bad connection where the switch is if you can jiggle it and it works.........make sure to clean the connectors on the inside and make sure you have a good solid connection
Napi333
#3 Posted : Monday, July 29, 2013 11:20:42 AM(UTC)
Napi333
Yes, it seems to be a loose connection. Where do these wires from the light switch go? I know one goes to the light, but where the other go? I think I may have to replace the wires and the part it goes to.
Napi333
#4 Posted : Monday, July 29, 2013 11:28:15 AM(UTC)
Napi333
Whirlpool ice and water not dispensing (Refrigerator & Freezer Repair)
by tr8d31 3/19/2013 8:41:30 AM(UTC)
