my estate washer function switch seems to have stopped advancing. It just sits and does what ever function is selected - forever. Is this problem the switch or something else?
Check to make sure you're getting 120v to the unit first off...........Then try different cycles throughout the dial..........you either probably have a cycle on your timer that's burned out or the timer itself is more then likely burned out......Check all the connections in the back of the timer as well make sure they are firm.............good luck
seems stuck in all cycles. New times 130 bucks. still cheaper than a new washer. Thanks
I followed the directions to remove the "Knob" but the disc under the know won't come off. So I can't get the timer off. I take it HumboldtRepairMan is in California? Too bad.
Yep northern California where the redwoods meet the beach and i have a house on the beach actually. Anyways go to sears parts website and they will show you a breakdown of how your machine comes apart.......be patient and you'll figure it out it's very simple.......
Groups: Expert
The timer disc should just pull off. You may need to use a couple small screwdrivers to evenly pry it loose.
This forum is not staffed. We are volunteer techs who check in periodically to help people out. We are not sitting at a computer waiting for people posting their questions. There are online paid services for that.
Eric
Thanks. They also have the cheapest part at 88$. I love the internet!
You were right! And I did all the work. $156.48 to get the KNOWN correct part local TODAY, some research and helpful hints and I'm back in business. Good job!
