i have a refrigerator and water is dripping from the freezer into the refrigerator. When I empty the freezer, there is ice frozen in the pan and the hose that runs to the bottom of the unit seems to be clogged, but open up after I squirt hot water with a turket baster. Does anyone have any idea whey the hose keeps on clogging?
You mean it stops back up quickly after you unstop it? If so you are not getting it clear enough I must drain water freely after you unstop it. Also you can mix baking soda with water and pour it down the drain. This will kill all the mold that may be clogging your drain.
it gets clear when enough hot water gets pored in the hose, then in a month or two it starts dripping again. I will try the baking soda and see what happens. thanks.some people say a bleach and water mix. Do you have any thoughts on that?
Bleach will also kill the mold and air pressure with a turkey baster etc will also help clear it out.
