debdbg
#1 Posted : Wednesday, July 24, 2013 8:43:12 AM(UTC)
debdbg
control panel on wall oven not working. code that is displayed is E6 F2 and when i push the start button the display will come on. the oven will turn off by itself and the display will go blank. when i push the start button nothing happens.
HumboldtRepairMan
#2 Posted : Wednesday, July 24, 2013 4:02:28 PM(UTC)
HumboldtRepairMan
The F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board.
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Whirlpool Wall Oven Dead After Self Cleaning Cycle (Oven Repair (including Ranges and Cooktops))
by Mattstone87 10/25/2019 3:45:35 PM(UTC)
Whirlpool wall oven display panel flashing, beeping (Oven Repair (including Ranges and Cooktops))
by kevinw 2/26/2014 4:08:31 PM(UTC)
Whirlpool Wall Oven Controls "stick" (Oven Repair (including Ranges and Cooktops))
by ROUSD 8/8/2012 12:19:17 PM(UTC)
Whirlpool Wall Oven - Electrical Smell (Oven Repair (including Ranges and Cooktops))
by VirtualGreg 3/1/2012 7:12:48 AM(UTC)
Whirlpool Wall Oven Problem (Oven Repair (including Ranges and Cooktops))
by mjmurray98@gmail.com 1/17/2012 1:55:34 PM(UTC)
Whirlpool Wall oven shut down after self clean (Oven Repair (including Ranges and Cooktops))
by Lellie 4/20/2011 8:00:43 AM(UTC)
Whirlpool Wall Oven control panel issues (Oven Repair (including Ranges and Cooktops))
by spkolluri 11/24/2010 10:55:48 AM(UTC)
Whirlpool Wall Oven making loud noise and shaking after heating (Oven Repair (including Ranges and Cooktops))
by meishc 9/7/2010 12:33:46 PM(UTC)
whirlpool wall oven not heating (Oven Repair (including Ranges and Cooktops))
by redfish1028 6/22/2010 12:55:30 PM(UTC)
Whirlpool Wall Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by hkelman 8/2/2009 7:40:45 AM(UTC)
Kitchenaid/Whirlpool Wall Ovens (Oven Repair (including Ranges and Cooktops))
by kodiakmonkey 3/26/2009 6:58:13 AM(UTC)
Whirlpool Wall Oven (Oven Repair (including Ranges and Cooktops))
by DCDi 3/20/2009 7:41:26 PM(UTC)
Whirlpool Wall Oven (self cleaning) will not hold temperature (Oven Repair (including Ranges and Cooktops))
by araki 11/13/2007 7:25:13 PM(UTC)
