Pauses then shuts off during wash cycle. Problem is intermitten. Sometimes no water intake during rinse/spin. Water inlets are ok. During wash countdown it pauses then shuts off with error message. Can then be restarted. Sometimes it all works, but I believe the problem is becoming more frequent. It is a Sears Kenmore, not a Maytag.
Need a model number before we can even come close to giving you ideas...............Also when the error code pops up copy it down and google search the code or ask on this forum
Well, don t I feel a bit foolish! Turns out that the cottage hot water supply was not on. Kiss check failure (keep it simple stupid).
