tmo314
#1 Posted : Monday, July 22, 2013 11:15:57 AM(UTC)
tmo314
The washer fills and the stops..it makes a buzzing sound.. replaced the lid switch last year, thought it was the motor coupler and replaced that but its not..it still spins and drains.
fairbank56
#2 Posted : Monday, July 22, 2013 12:20:48 PM(UTC)
fairbank56
Groups: Expert
Missing a number in the model number. Does the timer advance on it's own after it stops filling?
Eric
tmo314
#3 Posted : Monday, July 22, 2013 7:18:53 PM(UTC)
tmo314
No it doesn't
fairbank56
#4 Posted : Monday, July 22, 2013 7:32:22 PM(UTC)
fairbank56
Groups: Expert
Does the buzzing come from the control panel area or down at the bottom front where the motor is. Need the correct model number of the washer, should be 11 numbers.
Eric
tmo314
#5 Posted : Monday, July 22, 2013 8:16:57 PM(UTC)
tmo314
Model 11025852991...buzzing comes from up top
fairbank56
#6 Posted : Tuesday, July 23, 2013 4:52:56 AM(UTC)
fairbank56
Groups: Expert
Check the number again, it is not coming up.
Eric
tmo314
#7 Posted : Tuesday, July 23, 2013 7:31:14 AM(UTC)
tmo314
11029852991
fairbank56
#8 Posted : Tuesday, July 23, 2013 8:48:46 AM(UTC)
fairbank56
Groups: Expert
Open control panel and determine if buzzing is from timer or speed select switch. Does speed switch have individual connections or plug type connector(s)? Does agitation work in any other speed?
Eric
tmo314
#9 Posted : Wednesday, July 24, 2013 6:16:35 AM(UTC)
tmo314
Agitator only works in spin...buzzing is coming from timer switch...speed switch has its own connection
fairbank56
#10 Posted : Wednesday, July 24, 2013 7:59:33 AM(UTC)
fairbank56
Groups: Expert
The pressure switch is located on the left side behind the control panel. With washer off, disconnect and jump together the violet and tan wires and start washer in wash cycle. If it still won't agitate, need to jump out the speed switch but need a clear photo of your wiring diagram. Diagram should be behind control panel. Assume you tried different speed settings. Problem could be timer, speed switch or motor. Need to rule out the speed switch. No noise from motor during agitate, correct? Motor is at bottom front of cabinet.
Eric
