MargretS
#1 Posted : Sunday, July 21, 2013 2:43:23 PM(UTC)
MargretS
My dryer blows its 220 degree Fahrenheit thermal limiter fuse within a few minutes after I install a new fuse, even with the fabric temperature dial set at medium instead of high.
Its model number is FSE747GES1. However, there seem to be at least two different versions of this model; mine is the version that has a wire connecting one terminal of the high temperature thermostat to terminal R of the timer. (Another version has a timer that has no terminal R, and thus no wire connecting the timer to the high temperature thermostat.)
I'm wondering whether it would be reasonable to replace the high temperature thermostat with a thermostat that will open at a lower temperature. The thermostat is marked L285-40F, which means it is supposed to open at 285 degrees Fahrenheit, which is hotter than the 220 degrees at which the thermal limiter fuse blows. For instance, would it make sense to substitute a thermostat that opens at about 250 degrees? If this makes sense, can you recommend a particular temperature and part number?
If I substitute a thermostat that opens at a temperature lower than 285 degrees, would the only negative side effect be that loads take longer to dry? Or does the dryer shut down and stay off if the high temperature thermostat opens? (The wire connecting the thermostat to terminal R of the timer makes me wonder whether the dryer will shut down, and if so, whether the drying cycle will automatically resume after the thermostat cools down.)
I've checked typical causes of overheating:
1. The exhaust vent does not appear to be blocked. (The condo building has fans that pull air through the exhaust vent in the wall behind the dryer, and I can feel the pull at the entry to the dryer's exhaust blower if I remove the dryer's front panel to expose the exhaust blower. The lint trap does collect lint, which means the exhaust blower does pull air through the lint trap. I empty the lint trap after every load.)
2. The cycling thermostat (which is mounted on the exhaust duct after the exhaust blower) opens when it gets hot, as it's supposed to do. (Unfortunately I'm not sure of the precise temperature at which it opens because I don't have an accurate way to control and measure temperature; it might not be opening at 135 degrees as its L135-15F marking indicates. If it's failed in a way that causes it to open at a temperature much hotter than 135 degrees, it could explain the overheating and fuse blowing.)
3. The heating coil isn't stuck on, since the fuse didn't blow with the fabric temperature dial set at "air fluff."
4. The back of the dryer is about 8 inches from the wall, which is closer than optimal, but that's how it has operated since it was new. (The design of the condo doesn't permit the dryer to be moved further from the wall, unfortunately.)
Thanks in advance for your assistance!
Margret
#2 Posted : Monday, July 22, 2013 2:43:36 AM(UTC)
http://www.appliancepartspros.c...ch.aspx?model=FSE747GES1
I am doing some guessing here as I cannot find a wiring diagram for this unit.
[COLOR="Blue"]For instance, would it make sense to substitute a thermostat that opens at about 250 degrees? If this makes sense, can you recommend a particular temperature and part number?[/COLOR]
You could run into problems here as the heater may start being controlled by the high temperature thermostat. These thermostats are just safety devices and their contacts will not last very long if the are switched on/off often.
[COLOR="Blue"]Or does the dryer shut down and stay off if the high temperature thermostat opens?[/COLOR]
No it does self reset. Opens at 285 and re-closes at 245 (re the -40 spec)
[COLOR="Blue"]1. The exhaust vent does not appear to be blocked. [/COLOR]
You could try the following to eliminate the venting for sure.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
[COLOR="Blue"]2. The cycling thermostat [/COLOR]
This is a possibility.
[COLOR="Blue"]
3. The heating coil isn't stuck on, since the fuse didn't blow with the fabric temperature dial set at "air fluff."[/COLOR]
Your conclusion may be wrong.
Many units remove power through a set of contacts is the timer when in air fluff so depending how/where the element grounded it may only get power in a heating mode. Without a diagram I am unable to confirm this.
I would check it with a meter though often you can see the grounding point.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut). This can be checked by heating up the face of the thermostat. It will not tell you where it actually opens but at least tells you thet it does open. I use my soldering gun but heating it on a stove top element will also work.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
MargretS
#3 Posted : Monday, July 22, 2013 9:42:45 AM(UTC)
MargretS
Hi, thanks for responding so quickly.
When you say to "try a run" with the dryer disconnected from the exhaust vent to see if it dries OK that way, do you mean I should connect a new thermal fuse to see whether it will blow? Or is there a way to try a run that doesn't risk wasting another thermal fuse? (For instance, shorting together the pair of wires that normally connect to the fuse so that the dryer can run temporarily without a fuse, and monitoring the temperature in that vicinity while the dryer is running to see if it stays below 220 degrees.)
What do you suppose is the purpose of the wire that connects the high temperature safety thermostat to pin R of the timer? Will it pause the timer when the thermostat opens at 285 degrees, so that the dryer will automatically resume when the thermostat cools off to 245 degrees? The other version of this model dryer lacks that wire, so I'm unsure of its purpose.
I can't check the louvers on the outside of the house, since this is a condo unit. The building has a system of fans that continually suck air through the vent in the wall behind the dryer. I can tell the fan is sucking air, because it will strongly hold a sheet of paper to the opening of the dryer's exhaust blower.
Is there a way to test for blockage in the exhaust from inside the dryer, without detaching the dryer from the wall vent? It's very hard to detach or reattach the dryer from the wall vent because the dryer is surrounded on three sides (right, left and back) by walls and kitchen cabinetry and is mounted on top of a front-loading washing machine. It's much easier to access the insides of the dryer through the front or top. It's even easier to remove the drum than to access the backside of the dryer.
The heating coil impedance measures 11 ohms, which seems about right. A visual inspection of the heating coil looks okay too: no points of contact between coil and dryer except for the insulating mounts and the two terminals. I'll check the impedance between dryer and each of the two terminals when I have time later today, to verify there are no shorts.
I'm not sure how to check the seals for air leaks.
The portion of the vent ducts that I can see--between blower and lint trap--are very clear; I cleaned them about a year ago. The blower looks pretty clean too. I don't use fabric softener, and the lint trap always collects some lint (which I remove after every load) which may mean enough exhaust flows through the exhaust duct to heat the cycling thermostat.
As I mentioned in my original post, I already verified that the cycling thermostat (L135-15F) opens when it gets hot, although I don't know the precise temperature at which it opens. (I put it in my oven next to a meat thermometer, and set the oven to 140 degrees. The meat thermometer needle rose beyond its 190 degrees end-of-scale.) I also verified the impedance across the other pair of terminals of the cycling thermostat: 28 kOhms, which matches the wiring diagram. Today I verified that the high temperature safety thermostat (L285-40F) opens when it gets hot, although I don't know the precise temperature.
#4 Posted : Monday, July 22, 2013 1:14:08 PM(UTC)
Yes. This just eliminates the vent sysytem as a possible cause.
[COLOR="Blue"]
Or is there a way to try a run that doesn't risk wasting another thermal fuse? (For instance, shorting together the pair of wires that normally connect to the fuse so that the dryer can run temporarily without a fuse, and monitoring the temperature in that vicinity while the dryer is running to see if it stays below 220 degrees.)[/COLOR]
You could do this.
I do not recommend it because there are lots of folkes out there that will just keep running it with the fuse shorted. Then when their house burns down they complain.
[COLOR="Blue"]What do you suppose is the purpose of the wire that connects the high temperature safety thermostat to pin R of the timer? Will it pause the timer when the thermostat opens at 285 degrees, so that the dryer will automatically resume when the thermostat cools off to 245 degrees? The other version of this model dryer lacks that wire, so I'm unsure of its purpose.[/COLOR]
I do not have a wiring diagram and do not like guessing.
I do have other Frigidaire diagrams and they are sort of backwards to what you say. The timer advances when the hi-limit or operating thermostat open.
I will try to explain, please excuse me if I loose you. One side of the heater is connected to L2 (black) (lets say left side)the other side of the heater (right side) is connected to the thermostats and then to L1. It is also connected to the R you refer to. When thermostats are closed you have L2 and L1 (240 volts) across the heater and it heats up. When a thermostat opens L1 is disconnected (heater cannot heat up) so you only have L2 on the left side. This voltage feeds through the heater so you also see it on the right side. And this now goes to R which drives the timer motor through a resistor which drops the voltage down to 120 for the timer motor. The heater does not get hot because the current draw of the timer motor is very low.
[COLOR="Blue"]
I can't check the louvers on the outside of the house, since this is a condo unit. The building has a system of fans that continually suck air through the vent in the wall behind the dryer. I can tell the fan is sucking air, because it will strongly hold a sheet of paper to the opening of the dryer's exhaust blower.[/COLOR]
Sounds OK but you are pushing air out so I cannot say if the venting is OK just because it has some vacuum.
[COLOR="Blue"]Is there a way to test for blockage in the exhaust from inside the dryer, without detaching the dryer from the wall vent?[/COLOR]
No.
It is a pain but may end up your last resort. The order I list things is arbitrary so if finding out if it is a vent problem may be the last thing you do as it is the biggest pain in the you know what.
[COLOR="Blue"]I'm not sure how to check the seals for air leaks.[/COLOR]
It is just visual. The drum is actually part of a vacuum as the blower suck air through it so if you has a large air leak the you would be sucking in room air and the thermostat would then keep your heater on.
Sounds to me that you are doing a very thorough job trying get to the bottom of this problem.
MargretS
#5 Posted : Tuesday, July 30, 2013 4:16:37 PM(UTC)
MargretS
Hi again,
I haven't been able to solve the overheating problem yet. I thought I'd fixed it by the following:
1. Vacuumed the lint from the wall vent, so I could see clear to the elbow which curves up to the roof fan. (It's an 8 floor condo building and my condo unit is on the first floor.)
2. Verified there was very little lint inside the dryer (by removing the exhaust blower housing so I could access inside the blower housing and inside the pipe that connects the blower housing to the back of the dryer, and by looking in the duct inside the front panel that's between the lint trap and the exhaust blower, and by checking the back of the drum).
3. Replaced the cycling thermostat (even though the old one may have been fine; it opened when hot but I couldn't accurately measure the temperature at which it opened) with a new L140-10F (purchased from AppliancePartsPro).
After doing all that, I tested the dryer Saturday morning (without a load of laundry). First, about 10 minutes with the fabric temperature control set at "air fluff," then about 15 minutes set at "medium" and then about 20 minutes set at "high." Most of the top of the dryer was comfortably warm to the touch, although the corner above the thermal fuse was uncomfortably hot. I placed an oven thermometer above the hot corner (with an oven mitt and towel over it to reduce the cooler kitchen air reaching the thermometer) and watched the temperature cycle up and down between about 145 degrees F and 110 degrees F, while the dryer was running set to "high" heat. So I assume the cycling thermostat was doing something right.
So that's why I thought I'd fixed it. But Saturday afternoon, when I tried to dry my first (small) load of clothing, the thermal fuse blew after about 10 minutes, and the dryer had been set only at "low" heat. The top of the dryer was uncomfortably hot all over, not just in the rear corner. I took the dryer apart to visually inspect whether something might have come apart, but everything was still in place.
Would the moisture of the afternoon load have made the difference between the morning tests that passed and the afternoon failure?
I uploaded 3 photos of the wiring diagram and 8 photos of the dryer innards to:
Flickr: Dryer monster's Photostream
I assume the exhaust blower is either failing to suck enough air through the drum or failing to push the air out to the wall vent. Several possible explanations come to mind:
(1) Blockage inside the wall vent, somewhere in the 8 floors long vertical section between the elbow and the roof fan.
(2) Leaky seal (which would be a double whammy, by reducing the hot air pulled from the heating coil through the drum and by cooling the exhaust so the cycling thermostat won't open at the right temperature).
(3) Exhaust blower wheel ineffective at pushing air into the exhaust pipe.
The exhaust blower wheel turns when I rotate the drum, so the only way I can imagine it could be ineffective at pushing air is if it's somehow migrated out of position inside the exhaust blower housing. But it's bolted to the motor which seems to be in its proper position, so is that possible?
There may be a leak around the felt seals attached to the inside of the front panel, that fit inside the rim of the drum. The upper felt (which has 3 white nylon glides on which the rim of the drum rests) is much thicker than the lower felt--you can see that in one of the photos--so I assume the difference in thickness causes at least a minor leak. But it ran okay like that for years.
I doubt there's a leak at the foam rubber seal where the duct below the lint trap meets the exhaust blower housing, because it looks okay to me. (It's shown in one of the photos.) I suppose I could try to test it by coating it with vaseline and checking whether the vaseline residue it leaves on the exhaust housing makes a solid circle.
Do you have any ideas about the possible causes of the overheating, other than disconnecting temporarily from the wall vent? I'm not sure I'll be able to reattach to the wall vent if I disconnect it, since I can reach the back of the dryer with only one hand and no eyes.
Many thanks for your help!
#6 Posted : Wednesday, July 31, 2013 4:02:55 AM(UTC)
All of the below are just educated or perhaps not so educated guesses as your problem has me grasping for straws.
Note: that I am off to the cottage for a week so will not be available.
You may want to start another post with a link to this thread. If other regulars on this forum see that someone has been working on a problem they will not have the time to take a look at all the posts. So having a post without my name on it should get you some additional input.
[COLOR="Blue"]3. Replaced the cycling thermostat.[/COLOR]
Si we can assume that the cycling thermostat is OK.
[COLOR="Blue"]After doing all that, I tested the dryer Saturday morning (without a load of laundry).[/COLOR]
I agree with you that this also seems OK.
Just one question, was there any heat from the unit in Air Fluff?
[COLOR="Blue"]the dryer had been set only at "low" heat. The top of the dryer was uncomfortably hot all over, not just in the rear corner.[/COLOR]
This points to an air flow problem.
[COLOR="Blue"]
Would the moisture of the afternoon load have made the difference between the morning tests that passed and the afternoon failure?[/COLOR]
Moisture will make a difference as to how often the heater is cycled as it takes more energy to raise the temperature of the air to a set point. But you were on low heat soit should have run OK.
[COLOR="Blue"]I uploaded 3 photos[/COLOR]
This was very helpful. I just wish I had seen something obvious to help resolve this problem.
[COLOR="Blue"](3) Exhaust blower wheel ineffective at pushing air into the exhaust pipe.[/COLOR]
It does look like the blower wheel has a lot of crud in it.
The white stuff in the picture you gave.
I would remove the metal face plate and clean it out.
May even be a good idea to remove the blower wheel from the motor.
I have never removed a blower wheel from a reversing motor.
It looks like it may have a locking nut on the end of the motor shaft and then the wheel screws onto the shaft. On normal units the blower screws on the shaft by a reverse thread. There is no locking nut because the blower rotation direction always tightens the wheel. I imagine the nut is there to lock it as when this motor reverses it would try to loosen the wheel.
On most motors you can place a wrench or vice grips on the pulley end (has two flat sides) to hold the motor shaft and then undo the blower wheel.
One thing to note is that on one direction motors often the blower wheel seizes onto the shaft and needs to be destroyed to get it off. I would not go this far in your case. If it does not come off the I would just clean it as best you can.
I do not know what this white stuff is. It could be residue from fabric softener so I would also check your filter screen. fabric softener (especially the sheets can coat the screen and then it has to be washed with soap and water to get it clean.
[COLOR="Blue"] is if it's somehow migrated out of position inside the exhaust blower housing. But it's bolted to the motor which seems to be in its proper position, so is that possible?[/COLOR]
I do not think it is possible for it to move when everything is bolted down. Also if it did move you would probably hear it as it would rub on the blower housing.
This is a long shot but try holding the motor shaft and turning the blower wheel. There is a remote possibility that the blower wheel is partially stripped so that when there is no resistance to air flow (empty) it turns OK but when you add clothes (resistance to air flow) it slips on the shaft.
[COLOR="Blue"]There may be a leak around the felt seals attached to the inside of the front panel, that fit inside the rim of the drum. The upper felt (which has 3 white nylon glides on which the rim of the drum rests) is much thicker than the lower felt--you can see that in one of the photos--so I assume the difference in thickness causes at least a minor leak. But it ran okay like that for years.[/COLOR]
Have you had what looks like rust marks or holes in clothes. This is an indication that they are getting between the frame and drum due to a mounting problem.
This and the rear support bearing is a possibility. The reason I say this is that when you put clothes in the unit you add weight to the drum which could open up an air leak. The glides do look fairly worn. I would also check the lower seal to see it it has even wear etc.
Check you rear bearing support for wear. If you have to re-lube it be sure to use a high temperature grease.
[COLOR="Blue"]I doubt there's a leak at the foam rubber seal where the duct below the lint trap meets the exhaust blower housing, because it looks okay to me. (It's shown in one of the photos.) I suppose I could try to test it by coating it with vaseline and checking whether the vaseline residue it leaves on the exhaust housing makes a solid circle.[/COLOR]
I also doubt this is the problem because adding clothes should not effect this seal.
[COLOR="Blue"]Do you have any ideas about the possible causes of the overheating, other than disconnecting temporarily from the wall vent? I'm not sure I'll be able to reattach to the wall vent if I disconnect it, since I can reach the back of the dryer with only one hand and no eyes.[/COLOR]
Your test seems to show that the vent system is OK re: it ran OK on high heat with no clothes in it. If it was a vent problem it should have blown the fuse when you ran the high heat test.
Guest (4)
