DenD
#1 Posted : Sunday, July 21, 2013 6:12:11 AM(UTC)
DenD
We had a flooded basement and now my washer wont run. I took the load out and ran the spin cycle to get the water out of the inside, but It wont start. It just pop a Lr msg. on the board. I unplugged it and tried restarting it and nothing happens.
HumboldtRepairMan
#2 Posted : Sunday, July 21, 2013 11:13:56 AM(UTC)
HumboldtRepairMan
LR code typically is locked rotor code.......but it's not a guarantee because you flooded your machine there may be water still in the connectors or components causing things to foul out or you may have multiple problems that will appear later on as a result of your basement flood......... Rotor Part #12002039
Flooded washer (Washer Repair)
by cachaco 2/14/2017 12:14:31 PM(UTC)
