ramjm_2000
#1 Posted : Sunday, April 19, 2009 6:58:55 PM(UTC)
ramjm_2000
My second bad Whirlpool/Whirlpool Gold appliance in 2 years :mad: !! Anyways, Based on some of the older posts and an inspection of my microwave, I narrowed the problem (I think) to the door switch. In fact when looking at the two openings that the door latches into, only the bottom has a black "switch" for the latch to make contact with. I'm pretty sure I can see where the top opening once had a black switch but has since broken off. Outside of the missing black switch and the lack of "cooking", the light and control panel work fine. If I try to cook something the timer runs down as if it were cooking and the light goes off as it normally would when it finishes, but there is no fan sound and the turn table does not spin.
Based on the schematic of the microwave it looks like there are a few parts that might be the problem a latch board?? or a replacement switch?? Also I'm hoping that I can make the repair without having to remove the microwave (it's in a custom wooden cabinet mounted above the oven). Thanks in advance for the help.
JR
ramjm_2000
#2 Posted : Saturday, April 25, 2009 6:55:35 AM(UTC)
ramjm_2000
JR
Anyone? Also does anyone know where to find the proprietary torx head tool to remove the bolts keeping the case cover on the microwave?
rydeon
#3 Posted : Saturday, April 25, 2009 4:02:29 PM(UTC)
rydeon
Does the torx screw have a pin in the center?? I am going to assume that you will have to remove it to make the repair. Door switch problems on micros are very common because we all tend to slam the doors on these things. The newer micros just wont handle the abuse as the old "built like tanks" ones will. Good luck!
-Paul
