buffb
#1 Posted : Wednesday, July 17, 2013 1:21:05 PM(UTC)
buffb
When on a large load the machine will fill 3/4 full of water and then starts to slowly drain back out. On other load settings one time it will fill and wash right and other times the water will start running but it must be draining at the same time because the nothing ever gets wet? Any idea where to start on this?
fairbank56
#2 Posted : Wednesday, July 17, 2013 1:57:29 PM(UTC)
fairbank56
Groups: Expert
The drain is likely siphoning due to the hose either being too low (32" min height from floor to top of hose) or the connection to the standpipe is sealed. There must be an air break there.
Eric
buffb
#3 Posted : Wednesday, July 17, 2013 2:00:55 PM(UTC)
buffb
Eric, thanks for the help. Will fixed the problem now. Buff
HumboldtRepairMan
#4 Posted : Wednesday, July 17, 2013 4:07:22 PM(UTC)
HumboldtRepairMan
Check to make sure your pressure switch hose isn't leaking. Remove pressure hose at tub side and check for residue in plastic from detergent and clean be careful don't want to break connection. Take the hose and blow into it to the pressure switch you should hear the pressure switch click on and off. More then likely you have a bad pressure switch sensing it's overflowing and attempts to drain water out. Ohm test the pressure switch.
fairbank56
#5 Posted : Wednesday, July 17, 2013 4:42:16 PM(UTC)
fairbank56
Groups: Expert
The washer doesn't work that way. It does not have any control to sense an overflow and initiate a drain. The pressure switch simply switches between fill and agitate.
Eric
HumboldtRepairMan
#6 Posted : Wednesday, July 17, 2013 4:46:10 PM(UTC)
HumboldtRepairMan
Yes your unit does it has a "water switch or pressure switch" behind the control panel board. Just follow the tube leaving the tub. Part number 21001554
fairbank56
#7 Posted : Wednesday, July 17, 2013 5:07:06 PM(UTC)
fairbank56
Groups: Expert
Yes, it has a water level pressure switch. It's function, in conjunction with the timer, is to switch between filling or agitating. It does not sense an overflow and cause the washer to drain.
Eric
buffb
#8 Posted : Wednesday, July 17, 2013 8:23:02 PM(UTC)
buffb
Eric, you were right the connection to the standpipe was sealed and now runs fine. Thank You for your advice and for the great site. Buff
Guest (4)
