Mary T
#1 Posted : Saturday, April 25, 2009 8:42:37 AM(UTC)
Mary T
I just replaced the heating element last night. Did one load of laundry, everything was working. Got up this morning, put in another load in the dryer and went to push the button and... no start. What can it be? Where to start? No manual and laundry is stacking up... Please help. It could be the fuse... but where can I find that?
#2 Posted : Saturday, April 25, 2009 11:23:07 AM(UTC)
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203979710.pdf
Unit has two thermal fuses one the blower (it is for the motor) and one on the heater (it is for just the heater).
If the thermal fuse on the blower is blown try to find out what caused it to blow.
Common causes are:
1. Clogged dryer vent pipe
2. Exterior vents not opening
3. Dirty or loose blower wheel
4. Dirty filter screen. Sometimes if you use fabric softener it can coat the screen drastically reducing air flow.
