Anoop
#1 Posted : Sunday, July 14, 2013 1:05:36 AM(UTC)
Anoop
Dear All,
My refrigerator, when turned on runs fine silent for almost half an hour, after that it turns off and then onwards in every 80 seconds, it tries to turn on but compressor stops after a noisy knock and shivering. I could feel the compressor almost hot.
After waiting for some time,I turned off the refrigerator, and when turned on after almost half an hour, it repeated the same as above. Where can be the problem ??
Start-relay and overload is locked into a small box which is re-vetted. So i couldnt break open it.Anybody, request your immediate advise on this regard.
Regards,
Anoop B
#2 Posted : Sunday, July 14, 2013 1:33:32 AM(UTC)
You have a hard starting compressor. You can try a new start device, worth a try, but probably will not solve the problem.
Anoop
#3 Posted : Sunday, July 14, 2013 1:46:15 AM(UTC)
Anoop
Could you pls elaborate..where should i check, what should i replace. Why you said it will not slove ??
#4 Posted : Sunday, July 14, 2013 2:26:09 AM(UTC)
Can not help till you post a model #
Anoop
#5 Posted : Sunday, July 14, 2013 2:52:58 AM(UTC)
Anoop
It is a Voltas, 165 Litre
Model:VP
1.10 Amps
230V
