bobgehrman
#1 Posted : Friday, April 24, 2009 2:20:46 PM(UTC)
bobgehrman
I have a problem with a Kitchenaid refrigerator. The fans and compressor do not come on (including the interior fan). The lights work and the water dispenser tries to work (disconnected from water source). I replaced the relay and starter, still not working. Can't find a wiring diagram.
Any ideas?
Drags1998
#2 Posted : Friday, April 24, 2009 3:57:37 PM(UTC)
Drags1998
Its either in defrost or the thermostat is bad, Turn the timer and see if it starts, If not, check the thermostat.:)
bobgehrman
#3 Posted : Saturday, April 25, 2009 8:35:03 AM(UTC)
bobgehrman
Thanks - looks like the defrost circuit board has a blown relay. Just replace the circuit board? What would cause it to blow?
Guest (4)
