2 Pages<12
#11 Posted : Tuesday, December 15, 2009 9:57:15 AM(UTC)
You are welcome, glad I could help
Have a Merry Xmas.
Daniel J
#12 Posted : Tuesday, December 15, 2009 10:29:05 AM(UTC)
Daniel J
Originally Posted by: denman Go to Quoted Post
Daniel J
Please start your own thread in this section using Post New Topic.
Adding to this one will just confuse things especially if yours is a more complicated fix.
Also your Model Number is short about 5 digits.
I already looked it up using my full model # and it was the same part number, same fix, ordered a new thermal fuse. Thanks.
src33
#13 Posted : Friday, July 12, 2013 10:49:43 AM(UTC)
src33
I have a Quiet Partner V as well, and same issue has happened once in the past. The repair guy tried pressing buttons and that did obviously nothing. He said I needed a new control panel and all I ended up needing was one part. It may have been the thermal fuse you mentioned above, but I thought it had a cylinder-like shape at the end of it, so not sure.
Same problem is happening again after a lighning storm about a year later. Hoping I can remember the part.
Guest (4)
2 Pages<12
