Larry Marshall
#1 Posted : 16 years ago
Larry Marshall
During the cleaning cycle the oven gave an error code F2 and began to beep. I hit cancel and waited an hour, the oven cooled down but the fan never stopped running. I disconnected the power and waited a day and then when I reconnected the oven the fan was still running and when I tried to use it the oven never heated. Please help....THANKS!
#2 Posted : 16 years ago
Model Search
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010312.pdf
Could be the temp sensor is shot
http://www.applianceaid.com/elecrange.html
See #7 and #8
Also check that the wires are OK
Larry Marshall
#3 Posted : 16 years ago
Larry Marshall
I looked at the service manuel and it could not help me on how to get the oven door unlock; therefore, I am unable to check any of the wiring because I cannot get to the screws to get it out of the wall. Any other suggestions besides getting a sledge hammer???
#4 Posted : 16 years ago
You did not say the door was locked.
Have you tried pushing the door in where the latch is and hitting cancel a couple times?
Larry Marshall
#5 Posted : 16 years ago
Larry Marshall
Thanks for your help. Sorry about not telling you about the locked door. We have been through so many trials. We tried pushing on the door and it did not work. We finally worked the oven out of the cabinet, took the top off and unlocked the door; however when we pushed the door shut, it locked again. It seems that the little motor that locks the door is still in lock mode. We are going to buy a new oven. Two years ago we bought and new control panel and now it is blown so we are utterly disgusted with this oven. I will never buy a Jenn Air again. We have already replace the mircowave above it. Thanks again for all your help!
