Slow steady blink . Where can I get the fault codes? I have replaced the control board. works a while, then blinks again Where can I get the fault codes?
Please see the attachment |
THIS FORUM IS DEAD!!!!!!! |
It has a steady blink on the heavy and normal when it finishes washing. Hard to get to start again. only happens sometimes. control board was replaced by me but had no change in the problem
Turn off breaker or unplug unit. Remove screws around door.....disconnect the interface/touchpad from the main control board. Turn power back on and if the unit starts to drain automatically or after you hit the start button the touchpad/interface should be ok. I'm suspecting maybe a main control or sump part below possibly. These units are also know for a small to moderate leak on some of the hoses underneath in the sump area causing faulty codes and acting weird sometimes. Good luck
