I have a side by side GE TFS22PPDABS fridge about 12 years old. The water worked this morning from the door of the freezer now an hour later nothing. The ice bucket is full but again being that something has gone wrong recently it may not mean it is working.The water reservoir in the fridge is not frozen. When I pull the water tubes from the water inlet valve and press the water demand button on the front the solenoid sounds like its trying but no water comes out. I stuck a tube n the outlet and pressed the water demand button and sucked on the tube and i can suck water through so its opening and closing with the press of the button but no flow. I checked continuity on the water valve and it only registered in the 300's where the video on the site said it should be 1000 - 1500. Has my part# wr57x10026 gone bad?
Also we had terribly low water pressure coming from the fridge (take about 30 seconds or more to fill up a glass) even though there is good pressure from the line in. Will this fix that too?
anyone? would love to get this problem solved right
