2 Pages12>
95yj
#1 Posted : Friday, April 24, 2009 1:13:48 PM(UTC)
95yj
I was looking for information on how disconnect the two halves of a split air conditioning unit without losing any freon. I'm not sure if the manual I have explains the installation since it is in español but I'm looking for general information for all mfgs.
Basically, the airco comes with the inside and outside halves separated and capped with the full freon charge in the condenser. During installation the copper tubing is connected between the halves and the unit is bled to remove air using the compressor of the unit and a set of airco gauges.
It is also possible to "suck" all the freon back into the condenser/compressor leaving the evaporator dry. This is used for disassembling the unit for moving or for cleaning the inside unit.
Does anyone have detailed instructions on how to separate the units without losing freon and to reinstall them? I have gauges and have recharged units before but have never worked on a split unit.
Thanks much.
icehouse
#2 Posted : Saturday, April 25, 2009 5:28:49 AM(UTC)
icehouse
Thanks much.
:confused: You say you have gauges and have recharged before ? Not for nothing but there is a lot of misinformation in your post. Just what are your exact qualifications ? If you do not mind me asking. :)
95yj
#3 Posted : Saturday, April 25, 2009 6:05:36 AM(UTC)
95yj
Obviously I am not an HVAC technician or I would not be asking these questions. I have fixed leaks in auto airco and recharged and I have also added freon to home units that were low and freezing up.
As far as what I'm capable of, I'm a network systems engineer, have worked as an auto mechanic, have remodeled my own homes, added additions, done major plumbing work, have rewired my own homes and replace electrical service panels (which by the way passed code from an inspector) so I am plenty capable. I fully understand how airco works although I haven't done much in the way of service.
My original post is based on seeing what others have done. I live on a small island and unlike living where there are a multitude of HVAC professionals, there's not a whole lot of difference between the skill level of the service engineer who comes out and overcharges you for simple maintenance and the average Joe with a decent aptitude for hands on. (This is by no means meant to be a slam on a qualified trained professional, but we don't have the luxury of having many of them down here and usually who you wind up with is someone who just barely knows what they are doing.)
So, set me straight; that's why I'm asking questions.
icehouse
#4 Posted : Saturday, April 25, 2009 6:14:34 AM(UTC)
icehouse
It is called CMA my friend and I can help you along if we can take the back slapping attitude and put it on ice. :)
95yj
#5 Posted : Saturday, April 25, 2009 6:22:44 AM(UTC)
95yj
I'm sorry; the previous post was not meant to be negative in any way. You asked a question and I answered. That's the problem with email, postings, memos, etc. There's no tone of voice. I just reread my posting and could see how as a whole it could be taken incorrectly. I also understand the CMA. I apologize for any misconception.
95yj
#6 Posted : Saturday, April 25, 2009 6:28:21 AM(UTC)
95yj
I notice on the web site in your signature that you have books available. Which would you recommend for the homeowner doing their own maintenance? I don't need to pass any tests or anything. I would just like to increase my knowledge level. Pretty much the only airco down here are split units (except for some businesses) since we only cool the room we are currently in at the time.
icehouse
#7 Posted : Saturday, April 25, 2009 6:33:19 AM(UTC)
icehouse
Okay now that we are on the same page. :)
1. Attach the gauge manifold to the high and low side charging ports on the condensing unit.
2. Remove the caps to gain access to the service valves. You will need allen wrenches to turn them as they are recessed.
3. Run the unit and gradually close down the high side service valve, while watching the low side, gradually close the low side until guage starts to lower. DO NOT bring into a vacuum. @ 2psi., shut electric disconnect and shut low service valve.
95yj
#8 Posted : Saturday, April 25, 2009 6:47:57 AM(UTC)
95yj
Kewl, that's the info I was looking for. Thanks much.
What about reassembling the unit after disconnecting the lines? What's the best way to bleed the air out of the lines when hooking the inside and outside unit back together?
95yj
#9 Posted : Saturday, May 2, 2009 5:03:10 PM(UTC)
95yj
Originally Posted by: sarah_9 Go to Quoted Post
Hey friend, better get the service of some expert technician, just one wrong move by you while removing it can cause great trouble to your AC. I think it is better idea to get it done by some experts than by your self.
That's helpful. Please read the third paragraph of my second post (the third in the thread) then comment again.
IHAA
#10 Posted : Thursday, May 7, 2009 7:56:09 PM(UTC)
IHAA
I wonder if the EPA has boats? Are you rich? I hope so. Even a de minimis should net you $32,500 in fines. How's your tan?
2 Pages12>
