clr0221
#1 Posted : Wednesday, July 10, 2013 5:33:00 PM(UTC)
clr0221
We recently moved in to a new home and when I started my dryer today for the first time it is not heating up..... I am not sure if we bumped something or what. Any suggestions?
#2 Posted : Thursday, July 11, 2013 1:59:46 AM(UTC)
Check the power.
The motor etc. runs off of half the line but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
nestSa
#3 Posted : Sunday, July 14, 2013 3:36:06 AM(UTC)
nestSa
