J1love
#1 Posted : Wednesday, July 10, 2013 6:09:58 AM(UTC)
J1love
My whirlpool frig/freezer combo is not working properly. The freezer is working, but the frig is not cooling. About a year ago, this problem presented itself and I was told to remove the back cover and defrost the coils. This worked and I didn't have a problem for a year! Now, the problem has returned and I was told to defrost the coils again. This time, it only worked for a week. What should I do next?
#2 Posted : Thursday, July 11, 2013 2:54:44 AM(UTC)
Parts for Whirlpool ED5FVGXSS00 Refrigerator - AppliancePartsPros.com
It does sound like a defrost problem so try the following.
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 6 in the Control Parts section ) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Unit Parts section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
I could not find it in the parts but it will be wired is series with the heater and clipped to the top of the evaporator coils.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Guest (4)
