06raptor700
#1 Posted : Wednesday, October 31, 2012 6:26:49 PM(UTC)
06raptor700
This past week our ice maker started having large chunks in the ice bin. There is a foam clip that keeps coming off of the bottom of the ice tray. It has a new water filter since this started and tonight i noticed that only 1 side of the ice tray is dumping ice out ,then when it fills the tray water is running over into the ice bin. Is the maker bad or whats going on. Thanks
#2 Posted : Thursday, November 1, 2012 2:28:21 PM(UTC)
Did it show any error code on the ice maker control display?
Here are the breakdown diagrams and Parts for Frigidaire FGHB2844LF5 Refrigerator - AppliancePartsPros.com
06raptor700
#3 Posted : Thursday, November 1, 2012 3:38:03 PM(UTC)
06raptor700
No it did not. Thanks
#4 Posted : Saturday, November 3, 2012 3:39:24 PM(UTC)
Run the diagnostic service mode as described in the attached file and post the results.
File Attachment(s):
Skiergardener
#5 Posted : Saturday, June 29, 2013 2:26:45 PM(UTC)
Skiergardener
Do you know where I can get a download of the rest of that service manual?
jshz2003
#6 Posted : Saturday, June 29, 2013 4:04:52 PM(UTC)
jshz2003
I could use the ice maker troubleshooting tree part of the service manual
ctimrman
#7 Posted : Thursday, July 23, 2015 3:10:09 PM(UTC)
ctimrman
I ran the diagnostic test from the pdf file, however I am still not able to determine why theye is no water going into make ice. I used code 5th and it worked is there more reference to the end the pdf where it refers to flowcharts?
