jamie_pancake@yahoo.com
#1 Posted : Wednesday, June 26, 2013 2:14:51 PM(UTC)
The water in the door freezes over night after thawing with a hair dryer.
The dispenser has had a heater added to the fill tube just behind the lever about a year ago and it has worked fine, till lately. Could the heater be bad this soon? The heater added was one GE tech line recommended.
#2 Posted : Wednesday, June 26, 2013 3:23:45 PM(UTC)
It is probably frozen further down. Check your freezer temperature, if below 5 degrees adjust the control to get it higher.
You may have to transfer the food to another fridg and turn it off till it thaws out.
