twjackson
#1 Posted : Wednesday, June 26, 2013 9:31:46 AM(UTC)
twjackson
the fan in the freezer is working but not freezing nor making ice & the frig is not cooling at all..plz someone help
#2 Posted : Thursday, June 27, 2013 3:08:54 AM(UTC)
I cannot find any info on the given model number.
Kenmore numbers are usually 3 digits, a period and then an additional 6 to 8 digits.
Find your model number - AppliancePartsPros.com
Is the compressor running?
Usually you can hear it but you should also be able to feel it vibrating.
If the compressor is on all the time (other than when in a defrost cycle) then remove the cover in the freezer so you can inspect the evaporator coils.
If they have no frost or just frost in one area (usually where the freon enters the coils) then you probably have a sealed system problem.
This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit.
Be sure that the compressor has run at least an hour before checking the above. If you do it during or shortly after a defrost cycle you will come to the wrong conclusion.
Guest (4)
Icemaker for Whirlpool Side by Side Frig (Refrigerator & Freezer Repair)
by gohuskers 7/27/2014 5:17:12 PM(UTC)
2002 side by side frig/freezer (Refrigerator & Freezer Repair)
by dcairway 1/18/2014 4:54:22 PM(UTC)
side by side Frigidaire (Refrigerator & Freezer Repair)
by capthank 3/11/2013 1:47:30 PM(UTC)
kenmore side by side frig is freesing (Refrigerator & Freezer Repair)
by david.loughborough 3/28/2012 6:55:32 PM(UTC)
Side by Side Frigidaire leaks at the filter (Refrigerator & Freezer Repair)
by tedyoder 3/19/2012 7:35:49 PM(UTC)
GE Side By Side Frig Cooling Problem (Refrigerator & Freezer Repair)
by thc888 12/23/2011 9:13:32 PM(UTC)
Side by Side Frigidaire not running after replacing a new defrost timer (Dishwasher Repair)
by JANOOTS59 5/22/2011 3:13:10 PM(UTC)
GE Side By Side Frig Stopped working, need help (Refrigerator & Freezer Repair)
by vparc 6/14/2010 7:20:04 AM(UTC)
side by side frig (Refrigerator & Freezer Repair)
by technician 5/4/2010 3:09:58 PM(UTC)
Jenn Air side by side frige warm on top shelves freezes in produce drawers (Refrigerator & Freezer Repair)
by taichichu 4/3/2010 2:24:52 PM(UTC)
GE side by side frig (Refrigerator & Freezer Repair)
by tlclark 12/9/2009 5:06:35 PM(UTC)
by teeitupflynn 8/6/2009 4:46:38 AM(UTC)
Whirlpool Gold side by side Frig (Refrigerator & Freezer Repair)
by kreece0511 3/28/2009 6:03:47 AM(UTC)
Relay replacement for side by side Frigidaire (Refrigerator & Freezer Repair)
by themntneer 1/30/2009 10:52:04 AM(UTC)
Side by side frig keeps running (Refrigerator & Freezer Repair)
by georgenglish 6/5/2008 11:22:38 AM(UTC)
