tookthelowroad
#1 Posted : Monday, June 24, 2013 10:46:13 PM(UTC)
tookthelowroad
Hey all new to this site but not to the problems with this washer. Went to move it away from the wall today only to find 90% of the hardware which keeps it in a box type shape was gone! Yes the upper lid and frame just came off in my hands and if it weren't for the old dryer on one side and the drywall on the other I might have had an unplanned trip to appliance dept at sears today. Luckily I have a screw driver and hammer so I think I'm gonna be ok. anyways while I had it flipped over and marveling at the holes where screws once resided I noticed what I believe is called the "Skate Plate" is not attached to anything, is it supposed to just float around in there, side to side up and down? I notice holes in it that look like they might harbor an 8 mil or 5/16 but like I said this is my first wash machine so I don't want to be that 16 year old with his first girlfriend if ya know what I mean. Thanks in advance.
Jeff
fairbank56
#2 Posted : Tuesday, June 25, 2013 4:36:39 AM(UTC)
fairbank56
Groups: Expert
The suspension plate (skate plate) is not "attached" to anything however it must be oriented correctly. It sounds like yours may have rotated out of place if it's as loose as you say. It sits on top of 3 wear pads on the base assembly and the plate has 3 of it's own wear pads on top of it that the tub support rests on. The 3 "arms" of the tub support should go over the 3 "points" of the skate plate. Check the condition of all the wear pads and the orientation of the plate. Also check the 3 suspension springs that hold the tub and tub support to the base assembly and the counterweight spring in the back.
Eric
UserPostedImage
