I wish I could talk to whoever designed the door for thee GE microwave model. Another quarter of a cubic inch of plastic in the handle design would have made all the difference.
That aside through, a quick note of caution. If your handle is loose, and your door frame moulding has cracked, don't just order the frame and plan on re-using the handle. The door frame cracked because the handle cracked. Both need to be replaced.
Disassembly was simple, and follows the other posts. The rear gasket comes out easily, with a bit of caution. The front of the door is really tough to get off. Since I had a spare, I didn't mind the damage, so I know of no easy way to get it out. Almost lost the glass while taking it off too...
