jeffreyhnatch1
#1 Posted : Monday, June 24, 2013 7:46:52 AM(UTC)
jeffreyhnatch1
The freezer and refrigerator will not cool. The lights work. It does not appear that any fans are working either.
#2 Posted : Tuesday, June 25, 2013 2:11:54 AM(UTC)
Parts for Whirlpool GD5SHAXNS00 Refrigerator - AppliancePartsPros.com
Sounds like you may be stuck in a defrost cycle is this has been longer than half an hour.
Try unplugging the unit for a couple minutes to see if it will rest/start up.
Then if it happens again I would replace the main control board.
File Attachment(s):
GD5SH.pdf (667kb) downloaded 2 time(s).
