luv2bake
#1 Posted : Saturday, June 22, 2013 7:25:43 AM(UTC)
luv2bake
Oasis machine. Several years back, the control board was replaced under "warranty" when everyone was having the issue. We just recently replaced the pump as it was making a loud grinding noise upon emptying. Now I am getting the UL code again. Sometimes it will go through the wash cycle no problem if I set the spin speed on low. Other times, it makes so much noise & almost does a bucking bronco imitation then will code with UL with about 9-12 minutes left. I am also noticing some water on the floor, but not every time.
I hate to put out for another control board unless I am sure that is the issue. I don't know where to start to try & determine if it could be something else. I am trying not to have to call Sears repair if I can help it. Any help is appreciated.:(:(:confused:
luv2bake
#2 Posted : Monday, June 24, 2013 10:06:46 AM(UTC)
luv2bake
I hate to spend a ton $ to call a repair person in unless I have to. Need an idea what it is. I would like to fix this myself. please?!
