lak
#1 Posted : Sunday, June 23, 2013 3:03:35 PM(UTC)
lak
We were gone for a week and had water turned off. When we got home, turned water on, the freezer/ice maker started making a loud grinding sound but won't make ice. The fridge is 17 years old...can it be fixed??
#2 Posted : Monday, June 24, 2013 2:30:58 AM(UTC)
Parts for FRS22WNC - AppliancePartsPros.com
Choose the closest match from Narrow Your Choices.
Sounds like a something is jammed.
I would remove the icemaker and let it thaw/dry out overnight.
Then reinstall it to see if it will run.
Here is a manual'
I do not know if it covers your unit but the info on the icemaker should be close to your icemaker.
http://appliancejunk.com...wnloads;sa=view;down=290
You will have to join the site to be ablw e to download the manual.
