hotfudge22
#1 Posted : Monday, June 17, 2013 6:25:08 AM(UTC)
hotfudge22
agitator is loud and makes sort of clicking noise louder on higher agitation i replaced agitator dog ears and surrounding parts with agitator parts repair kit but still does it and wraps clothes around the agitator in center what else needs replacing
l
fairbank56
#2 Posted : Monday, June 17, 2013 9:05:38 AM(UTC)
fairbank56
Groups: Expert
Run with lid open and no clothes in tub. Is the lower agitator going back and forth as it should? Top agitator (auger) should only be driven in clockwise direction when lower agitator goes clockwise.
Eric
hotfudge22
#3 Posted : Thursday, June 20, 2013 5:04:04 AM(UTC)
hotfudge22
yes the lower agitator is going back and forth
fairbank56
#4 Posted : Thursday, June 20, 2013 11:09:41 AM(UTC)
fairbank56
Groups: Expert
It may be that the teeth inside the auger that mate with the dogs are worn out as well which would require replacement of the auger. Pull auger and check up inside for condition of those teeth.
Whirlpool 3950581 Clothes Mover - AppliancePartsPros.com
Eric
