aaronii
#1 Posted : Sunday, December 9, 2007 3:31:30 PM(UTC)
aaronii
My dryer turns on but wont heat and keeps running what do I look for.
#2 Posted : Monday, December 10, 2007 11:29:26 AM(UTC)
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
cepeters
#3 Posted : Friday, April 18, 2008 5:33:29 AM(UTC)
cepeters
I am having the same problem, my dryer will run until I turn it off but it never heats up. I have replaced the thermal fuse, cycling thermostat and timer, it still runs until I turn it off but never heats up. What now?:mad:
