my wp ref stopped dispenseing ice ice maker working fine ,will not switch to ice on front key pad and ref temp button will not go up(in temp) how do you tell if its the key pad or the control-elec
Groups: APP Team
Hi. Based on the information you provided the touch pad should be replaced. Before ordering it check if the connection to the control board is good. The overlay Part number: AP4588531
I have this exact problem and I am interested to know if your problem was fixed by replacing the touch panel.
