I have a Samsung RFG295AARS refrigator. It has two evaporastors. the frigge department is freezing up. The temp dispaly read 46 degrees but it is 30 degrees or below in the fridge department I have replace the control board twice, replaced thermostat and thermister. the self diagnois read out is -88 88. The evaporator in the frigde department is not freezing up. The fridge gets too cold.
Originally Posted by: AKE  I have a Samsung RFG295AARS refrigator. It has two evaporastors. the frigge department is freezing up. The temp dispaly read 46 degrees but it is 30 degrees or below in the fridge department I have replace the control board twice, replaced thermostat and thermister. the self diagnois read out is -88 88. The evaporator in the frigde department is not freezing up. The fridge gets too cold. If your not set up to make ice, be sure your "ICE OFF" is selected.
