treborssag
#1 Posted : 12 years ago
treborssag
I just replaced the control module on a Bosh Axxis Washer (WAS20160UC).
I powered the unit and initiated the variant coding sequence. I closed the door and rotated the dial to the 9 o'clock position. 9 solid lights came on, 4 went out. 5 LEDs in a column directly above the spin selection button remain solidly lit. All connections are firm.
I cannot get to the start/pause flashing LED so that I can program the board. Any advice would be greatly appreciated.
boschsucks1
#2 Posted : 12 years ago
boschsucks1
Hi - I am having the exact same issue. Did you ever find a solution?
