I have a GE side x side refrigerator model # GSH22JFTAWW. The refrigerator stopped cooling and nothing would work but the lights inside so I replaced the mother board part # WR55X10942. When I did the compressor and fans started working again and it is cooling fine. Now to the problem I have..... The temp controls for this unit is located on the outside of the freezer door where the ice and water dispense. Ever since I replace mother board the temp control will not work it just keeps blinking 0 0 cannot adjust at all and the water and ice dispenser will not work either. So I replaced that control board also but did not fix the problem. Need help asap since I cannot control temp some stuff in refrigerator side is freezing.
Rank:: Member
Soon as a replaced the electronic board the control on the freezer door kept blinking 0 0. I wasn't sure if there was a solution to resolve this issue yet or not.
Please help.
thanks
Did anyone get this problem fixed yet?
