BaileyH
#1 Posted : Tuesday, June 11, 2013 1:07:53 PM(UTC)
BaileyH
My kenmore side by side freezer is freezing up and causing refrigerator to get hot, I have tried cleaning the condenser coil and evaporator to but after about a week it is frozen up again, what should my next step be? thanks
#2 Posted : Tuesday, June 11, 2013 3:39:57 PM(UTC)
You have an Amana refrigerator, go to web site www.applianceaid.com and do the manual defrost procedure for an Amana.
If the compressor stops, but you get no defrost action, you most probably have a bad defrost thermostat ( your adaptive defrost board is ok) clipped to the top of the evaporator, just replace it using this parts site. If you have a meter you can check the defrost heater, most probably ok.
