HLFRISCH
#1 Posted : 12 years ago
HLFRISCH
The dishwasher won't pump the water out. I checked the line, the disposal unit and the inside of the dishwasher. There was no blockage. When trying to run it, the solenoid was operating at the correct time and the motor was running. I replaced the solenoid and pump with new parts. It still wouldn't pump. I put the old parts back in (so I could return the new parts) and it started working. Three weeks later, it stopped. I took everything apart again and it started working. I have no idea why, but I'm sure it's going to stop again. Any ideas?
Thanks.
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Look at the breakdown diagram and locate the little ball #454 on the top of the sump inlet. By moving up and down inside the tube, this ball opens and closes the path for the water to drain. Check if the ball is there and moves freely.
Here are the breakdown diagrams and Motor-Pump Mechanism parts for GE GSD2100N10BB - AppliancePartsPros.com
Please, post the results.
Simon.
HLFRISCH
#3 Posted : 12 years ago
HLFRISCH
That ball is in part #510. Is it supposed to be in part #505?
Howard
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Yes, it goes up and down in the tube inside the sump #505.
Simon.
jdmcnair
#5 Posted : 10 years ago
jdmcnair
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
I signed up to this forum just to say thank you. Seriously, THANK YOU!!
I've been pulling my hair out over this for 2 weeks now, no signs of why my dishwasher wasn't draining even though the pump is working and the flapper solenoid was engaging, etc. This is the ONLY post I found that mentioned the little ball as a crucial component for draining.
I was missing that ball altogether, and I wasn't draining a damn drop. Block off that passage, and it drains perfect.
Dishwasher won't pump water out (Dishwasher Repair)
by BoBenedict 13 years ago
