karalyn75
#1 Posted: : Monday, June 10, 2013 3:07:56 PM(UTC)
karalyn75
I washed a king sized comforter and it stopped after it washed, before it rinsed and left the tub full of water and it won't spin or drain on every cycle. The only thing it will do is fill with water. Help please!
Simon / APP Team
#2 Posted : Monday, June 10, 2013 4:14:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is a bad lid switch #6 on the diagram Part number: 8318084
To be sure, unplug the washer, open the control panel and install a temporary jumper wire between the Gray and White wires of the lid switch.
Turn the washer on, if it starts - replace the lid switch.
Here are the breakdown diagrams and 01-Top and Cabinet Parts parts for Maytag MVWC300VW0 - AppliancePartsPros.com
Please, post the results.
Simon.
Maytag Top Loading Washer A9600 (Washer Repair)
by sdpeabody@yahoo.com 4/11/2020 8:24:39 AM(UTC)
Maytag top loading washer (Washer Repair)
by WATTSAIA 9/18/2011 11:55:17 AM(UTC)
Maytag Top Loading Washer - purchased 1997 (Washer Repair)
by Atlas1 1/30/2010 1:33:34 PM(UTC)
Maytag top loading washer tub leaking (Washer Repair)
by Rod Gray 1/28/2010 12:49:26 PM(UTC)
Maytag Top Loading Washer (Washer Repair)
by Lisa1966 12/21/2009 10:37:32 AM(UTC)
Maytag top loading washer leaking in spin cycle from bottom (Washer Repair)
by kleve 7/23/2009 7:36:13 AM(UTC)
by dpalatka 3/7/2008 2:47:48 AM(UTC)
