hksiu97
#1 Posted : Monday, June 10, 2013 3:26:27 AM(UTC)
hksiu97
No water dispense, water tube frozen at freezer door near dispense area.
Have changed all 3 temperature sensors (WR55x10025) , Defrost thermostat (WR50x124), and Main Control board (WR55X10942).
Worked fine after 6 days, then had to reduce the freezer temperature setting (9 is max. very cold) from 5 (mid point/normal setting) to 2, now to 1, and still have problem. Freezer temperature -10 degree.
Please advice the correct spec on the temperature sensor part (wr55x10025), what should be the resistance reading at 32 degree F, and at 68 degree F? Thanks.
