I have a Whirlpool Quiet Partner III Dishwasher (2-3 y.o) that worked this morning. This evening when the door was closed it did not activate nor does the control panel lights illuminate. Checked the breaker, receptacle and power cord plug. All found intact.
Is there a reset button? Any ideas why no power? Btw everything else in the kitchen is powered.
Thank you in advance for any help.
The model number appears as GU2500XTPS0
A Model Number may help others help you |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A Model Number may help others help you The model number appears as GU2500XTPS0
Originally Posted by: denman  Thank you very much. Where do you find the "Control parts" section? I've looked through the owner's use and care guide manual, is that a repair manual you've referenced?
