ssmith9183
#1 Posted : Saturday, June 8, 2013 5:44:23 PM(UTC)
ssmith9183
Not sure on how old the washer is I just got it from a friend and the washer will not stop filling, it keeps filling and then drains and fills again unless I go and turn the dial to make it wash and it does the same thing on the rinse cycle what is wrong with it and is it something I can fix on my own
fairbank56
#2 Posted : Saturday, June 8, 2013 6:01:07 PM(UTC)
fairbank56
Groups: Expert
We need the model number to be able to help you.
Eric
ssmith9183
#3 Posted : Saturday, June 8, 2013 8:14:17 PM(UTC)
ssmith9183
Lxr6432jq0
fairbank56
#4 Posted : Sunday, June 9, 2013 4:18:45 AM(UTC)
fairbank56
Groups: Expert
If it's simply draining while filling and the drive motor is not running, it is likely a siphoning problem due to either the drain hose is too low or you have created a seal where the drain hose goes into the drain standpipe. You cannot have an airtight seal where the hose enters the standpipe. If it fills to normal level, cuts off and then the motor comes on and drains the water out, that's another problem altogether. Let us know.
Eric
UserPostedImage
ssmith9183
#5 Posted : Sunday, June 9, 2013 6:02:58 AM(UTC)
ssmith9183
um ok well no the only time that it drains when the water is filling is if the water gets to a certin level and i dont turn the dial to wash is when it drains and then fills again. But thats what i wanted to know why is it doing that and why do i have to manuly turn the dial to wash?:cool:
fairbank56
#6 Posted: : Sunday, June 9, 2013 8:01:14 AM(UTC)
fairbank56
Groups: Expert
Apparently, you have a siphoning problem because the drain hose is too low or there is a seal at the drain hose standpipe hookup. This is not allowing the water to reach the level at which the water level pressure switch will engage and power the timer and drive motor.
Eric
