SARAH CLARKSON
#1 Posted : Wednesday, April 22, 2009 3:52:10 PM(UTC)
SARAH CLARKSON
i bought an ignitor to replace the old one. They upgrade the ignitor it looks the same except. The old one has 2 uneven wire .1 wire has a metal piece at the end . while the other is connecting to a plastic piece. which is connect to to wire which connect to the side of the oven at the bottom. the new ignitoe only has two wire and2 white caps. what to do? I threw the old piece away. can i purchase this additional piece separtely. what is this part called so i can contact the company. please help thank you:confused:
#2 Posted : Thursday, April 23, 2009 3:26:06 PM(UTC)
That piece is probably a solderless wire terminal. You can buy this terminal separate, but you need a crimping tool to install this terminal and to splice the second wire. The part you called "white cap" is a high temperature porcelain wire nut.
- The part number for the wire terminals (pack of 15) is AP3440459
