2 Pages<12
#11 Posted : Thursday, April 23, 2009 3:01:29 PM(UTC)
Locate the Bake gas safety valve. Remove the two wires from the gas valve terminals and check for continuity between them. If the circuit is open then the gas valve has to be replaced.
Post the results.
jimneaf
#12 Posted : Thursday, April 23, 2009 3:06:49 PM(UTC)
jimneaf
Thanks, I'll give it a try. Jim
jordan2000
#13 Posted : Friday, December 28, 2012 5:51:36 PM(UTC)
jordan2000
I have the exactly problem and same model oven. The rang works well. I have replaced the igniter with a new one. The igniter just doesn't glowing. Then I checked the continuity of the igniter and the continuity of the gas valve. They are all good. What could be wrong? Thanks.
#14 Posted : Friday, December 28, 2012 6:02:02 PM(UTC)
Originally Posted by: jordan2000 Go to Quoted Post
...I have the ... same model oven...
You are third or fourth person on this thread. Model numbers were different. :confused:
2 Pages<12
