Neither hot or cold water is coming in washer. Checked and cleaned water inlet valve screens and also replaced water inlet valve itself. Still no water. If washer is manually filled it will work. :eek: Please help!!! :eek:
Groups: Expert
Could be a faulty load sense switch or ATC switch, depending on model version. Need to know version of your washer. There should be another number in the model number. Last number after ESVW should be a 1 or 0. Which is it? Ok, I see you have ESVW1 listed there. Looks like a faulty load sense switch. First, try unplugging the two wiring harness connectors from the switch and plug them back in and also unplug the pressure hose and reconnect. If problem still exists, replace the switch. http://www.appliancepartspros.c...w10248240-ap4459660.htmlEric
