kevineprice
#1 Posted : Thursday, May 30, 2013 10:12:42 AM(UTC)
kevineprice
My Fridgedaire FDB1050REM2 doesn't drain.
I thought it was because of the drain line.
It is clear.
I can run a wet/dry vac in the drain line and pull all of the water through it.
I then thought it was the drain pump.
I bought one from AppliancePartPros.com exact same part, replacement was easy, but still doesn't drain.
It cycles in every other way....but no drain.
Why?
jociadam
#2 Posted : Sunday, January 31, 2016 7:37:47 AM(UTC)
jociadam
Did you ever find out what was wrong with your dishwasher? Mine is doing the same thing. I made sure the food trap, filter and pump are clear of debris. I unhooked the drain line from the p-trap under the sink and it pumps out the water fine, so there isn't an obstruction. After it goes through all the cycles, there is about two inches of clear water standing in the bottom of the tub. My husband told me to go on and call a repairman, but I am pretty handy at fixing our washer, dryer, water heater, etc., and I can't believe this would be more difficult to repair. Just curious if you found out what was wrong with yours.
Cindy
