I have a Pepsi branded mini fridge that I got from my father last summer. He had it from Yellowknife and kept it outside one year. He said it worked. I got it home, it turns on. From what I can tell, the condenser works great (nice noise when plugged in, and fan at the back bottom of the unit spins). The issue is the inside fan does not spin. I tried spinning it manually when it was turned on in case it needed a helping hand and had no luck. Does anyone have any suggestions as to what may be the required fix? I have no idea how to fix this kind of thing and searching did not help. Taking some pictures now and will post them in an edit shortly. Hopefully the images will help! Images Below:   ^^^ That's the fan that doesn't spin
Found some extra not very helpful information about this cooling unit.
It's brand is QBD. I looked them up, found a website for them, although unfortunately they no longer carry this model (almost vintage labeling by today's Pepsi logos).
I have sent them an email to find out any possible information about the unit and hope to hear back from them soon.
If anyone has any insight, would still appreciate the direction to go in, otherwise I'll just try dismantling it myself haha.
