viking47
#1 Posted : Wednesday, May 29, 2013 6:28:46 AM(UTC)
viking47
Freezer stays at near zero all the time, does not respond to temp setting on thermostat. Replaced thermostat and the problem remains the same - either always on or off. Defrost timer appears to work as it does cycle off for defrost. Fridge side setting is at "cold", about halfway on the knob and the fridge temp is fine.
Not sure what to try next?
Thanks for the help.
#2 Posted : Thursday, May 30, 2013 2:49:09 AM(UTC)
Sorry but I do not understand your problem.
The recommended temperature for a freezer is 0 to 5 degrees F so you are OK as far a temperature.
viking47
#3 Posted : Thursday, May 30, 2013 3:59:58 AM(UTC)
viking47
Denman - thanks for the reply. I didn't realize that the freezer was supposed to be that cold. I thought 10-20 was a more reasonable range. So, perhaps I don't have a problem then. Although I'm still curious as to why changing the position of the thermostat knob in the freezer would have no effect on the temperature of the freezer - coldest setting to just before turning it off, the temperature remains constant at about 2 degrees.
Thanks - Viking
#4 Posted : Thursday, May 30, 2013 4:15:33 AM(UTC)
I am not sure what is the cause of the thermostat not having any effect.
How long do you wait after adjusting the thermostat to check the temperature? It can take like 24 hours or more.
A lot depends on how much food etc. is in the freezer.
If there is lots then you have a large thermal mass that will take a long time to equilibrate especially if you are going to a warmer temperature.
As long as your temperature is within spec and the unit's compressor is cycling correctly I would not worry about it.
viking47
#5 Posted : Thursday, May 30, 2013 4:37:01 AM(UTC)
viking47
Thanks again. My orignal concern was that the compressor seems to be on quite a lot. It's actually quite rare that I hear the compressor off. I did notice a sticker inside the freezer door about a 'service kit' being applied to the fridge, something about R12 refrigerant (I'm not at home to look right now). So, my original hypothesis was that near zero was too cold, the result of a bad thermostat and the compressor running too much.
I'll do some more long term testing on changes to the thermostat to see how it does. We're getting ready to leave town for a bit, so the freezer is actually fairly empty right now.
Thanks for your help and insight. I'll post back to the thread if I find anything interesting.
Viking
